Fresh Raspberry Pi Install, Cannot Install RcloneView
So I just spun up a 100% fresh Raspberry Pi with the latest Debian OS, its been updated, and I BELIEVE I installed Rclone correctly… however I followed this guide:
But it gives immediate errors… such as:
dpkg: error: cannot access archive ‘rcloneview_*_arm64.deb’: No such file or directory
Looks like the information there is wrong, so I was able to use wget to pull down the latest, ok cool so then I ran:
sudo dpkg -i rclone_view-1.4.1+1-linux-aarch64.deb
I think it worked, but then it said something like “Sorry to see you go.” and then when running: /usr/share/rclone_view/rclone_view
(which is also wrong in the guide) I just get this error:
(rclone_view:2133): Atk-CRITICAL **: 12:49:58.514: atk_socket_embed: assertion ‘plug_id != NULL’ failed
Gdk-Message: 12:49:58.881: Unable to load from the cursor theme
So I gave up… hoping there is an updated guide, is there a way to roll back and clean up the files I did install probably improperly and run a script again to so it all right? Is the naming of the files/program changed? Can the guide be updated?
Please help! I was planning to purchase but glad I tested first as this didnt go so well :frowning:
Hi,
Thank you for the detailed report — we’re sorry the guide let you down.
The ATK/Gdk errors are not an install problem — they’re a display problem:
Atk-CRITICAL: atk_socket_embed: assertion ‘plug_id != NULL’ failed
Gdk-Message: Unable to load from the cursor theme
These are GTK runtime errors that happen when a graphical app launches with no display server available. A fresh Debian Lite / headless Raspberry Pi has no X11 or Wayland session. RcloneView has nowhere to render. It will always fail like this on a headless Pi unless you set up a display.
Cleanup:
Remove the broken install:
sudo dpkg -r rclone_view
or if that doesn’t work:
sudo dpkg --purge rclone_view
Verify it’s gone:
dpkg -l | grep rclone_view
We appreciate you testing before purchasing and taking the time to document this so thoroughly. The fix will be live shortly.
Apologies again for the frustration.
Thanks for the info I was able to get it working, and then purchased the plus license! But I have some other issues but its a new topic :slight_smile:
