Unable to register on Linux mint
The input of emails and license key are frozen. The cursor changes from the arrow to the input symbol, but I am not able to input any text. Finally the app freezes. I assume that it might be a Javascript issue.
Thanks for using RcloneView.
What version of Mint do you use? ARM or x86_64?
Did you install RcloneView using DEB, or are you running it as an AppImage?
Its an Intel CPU x86_64 and I installed the DEB version. On Windows the registration screen is weird but it works.
