Windows 11, latest build, latest version of app downloaded from rcloneview.com
- Launched app several times over the past week
- set up remotes
- transferred many files, works great!
- Launched app today
- UI is nowhere to be found, can’t see the icon in the taskbar, no windows, no remotes, nada
- see app running in Task Manager
- reinstall, reboot, reinstall, reboot, purchase Pro version, reinstall, reboot, rinse repeat
- disable Windows Firewall for rclone view
- rinse repeat
- nothing
works on other computers on the same network
rclone works as expected in Powershell
any help or advice is appreciated. thanks.
