Hi All, just got a life time license and I’m trying to get this working on my linux system. Right now I have rclone installed via a Distrobox and running the AppImage of RCloneView. I’m running an immutable desktop which is why I’ve got rclone in a distrobox, to avoid using rpm-ostree
for smooth OS updates down the road.
The issue I have is that it seems to expect GNOME and I can’t figure out a work around for my KDE Plasma system. I’m running Bazzite which is essentially Fedora Kinoite an Atomic spin of standard Fedora. It supports system tray icons by default and all my other apps work fine (i.e. MEGASync, Steam, etc.).
Other than having to keep the RCloneView open it works great via the AppImage, installed via RPM file on the distrobox, not so much. The AppImage seems to be the only one that’ll successfully mount the remote cloud drives.
Any ideas?
OS and System Details:
Operating System: Bazzite 42
KDE Plasma Version: 6.4.0
KDE Frameworks Version: 6.15.0
Qt Version: 6.9.1
Kernel Version: 6.14.6-109.bazzite.fc42.x86_64 (64-bit)
Graphics Platform: Wayland
Processors: 20 × 13th Gen Intel® Core™ i9-13900H
Memory: 32 GiB of RAM (31.0 GiB usable)
Graphics Processor 1: Intel® Iris® Xe Graphics
Graphics Processor 2: NVIDIA GeForce RTX 4080 Laptop GPU
Manufacturer: ASUSTeK COMPUTER INC.
Product Name: ROG Zephyrus M16 GU604VZ
System Version: 1.0
