jake
June 25, 2025, 8:35pm
1
Hi,
I have installed rcloneview on Linux Mint and also on Ubuntu and they are in VMware Pro virtual machines and when I run the software it runs upside down in a foreign language. It doesn’t matter if I’m running the app image or the Debian installer they both do the same thing.
Running version 0.7.310
Any suggestions?
Hi,
This appears to be a known issue with recent versions of the Flutter engine:
Flutter window upside down on Linux Desktop under VMWare Workstation · Issue #163076 · flutter/flutter · GitHub
However, it doesn’t occur consistently. For example, we’re also developing a Linux version of our app using VMware, and we haven’t encountered this issue there.
We’ll need to wait for the Flutter team to address and fix this issue in a future update.
Thanks for your feedback.
jake
June 26, 2025, 1:34am
3
Thank you for the information.
By the way, I’m running the cinnamon desktop on both machines. Perhaps another desktop would work? This might be why you haven’t seen the issue.
That could be the case. In a GitHub issue, one user mentioned that the problem doesn’t occur in a Wayland environment, so the desktop environment might indeed be a factor. It’s possible that Cinnamon is triggering the issue in some setups.
opened 08:32PM - 11 Feb 25 UTC
platform-linux
c: rendering
a: desktop
P2
team-linux
triaged-linux
### Steps to reproduce
flutter create my_app
flutter run -d linux
### Expect… ed results
the app should run not upside down
### Actual results
Then the app is upsode down only compiling for linux desktop
works normal for chrome
### Code sample
<details open><summary>Code sample</summary>
```dart
[Paste your code here]
</details>
### Screenshots or Video
<details open>
<summary>Screenshots / Video demonstration</summary>
[Upload media here]
</details>
### Logs
<details open><summary>Logs</summary>
```console
[Paste your logs here]
</details>
### Flutter Doctor output
<details open><summary>Doctor output</summary>
```console
~/workspace/my_app$ flutter doctor -v
[✓] Flutter (Channel stable, 3.27.4, on Debian GNU/Linux 12 (bookworm) 6.1.0-31-amd64, locale pt_BR.UTF-8)
• Flutter version 3.27.4 on channel stable at /home/user/flutter
• Upstream repository https://github.com/flutter/flutter.git
• Framework revision d8a9f9a52e (11 days ago), 2025-01-31 16:07:18 -0500
• Engine revision 82bd5b7209
• Dart version 3.6.2
• DevTools version 2.40.3
[✓] Android toolchain - develop for Android devices (Android SDK version 34.0.0)
• Android SDK at /home/user/Android/Sdk
• Platform android-34, build-tools 34.0.0
• Java binary at: /home/user/android-studio/jbr/bin/java
• Java version OpenJDK Runtime Environment (build 17.0.6+0-17.0.6b829.9-10027231)
• All Android licenses accepted.
[✓] Chrome - develop for the web
• Chrome at google-chrome
[✓] Linux toolchain - develop for Linux desktop
• Debian clang version 14.0.6
• cmake version 3.25.1
• ninja version 1.11.1
• pkg-config version 1.8.1
[✓] Android Studio (version 2022.3)
• Android Studio at /home/user/android-studio
• Flutter plugin version 77.1.1
• Dart plugin can be installed from:
🔨 https://plugins.jetbrains.com/plugin/6351-dart
[✓] VS Code (version 1.97.0)
• VS Code at /usr/share/code
• Flutter extension version 3.104.0
[✓] Connected device (2 available)
• Linux (desktop) • linux • linux-x64 • Debian GNU/Linux 12 (bookworm) 6.1.0-31-amd64
• Chrome (web) • chrome • web-javascript • Google Chrome 133.0.6943.53
[✓] Network resources
• All expected network resources are available.
• No issues found!
</details>
jake
June 26, 2025, 2:05am
5
Hi,
I restarted my ubuntu with the regular desktop interface for ubuntu and your software works like its supposed to. Well, I’m not in vmware in this environment.
Inside vmware, even the normal default ubuntu doesn’t work right.
