Access to local drive from Android
I mounted new local drive from rcloneview but can i access to this drive on Android using a file explorer? If yes, please help me how to do because i’m a newbie.
Thanks for your question!
A drive mounted with RcloneView on Windows or macOS cannot be accessed directly from Android using a file explorer. The mount only exists inside your computer’s operating system — Android cannot see it over USB or Wi-Fi.
However, you can access the same remote storage on Android by using an app that supports rclone or the same cloud provider (Google Drive, OneDrive, S3, etc.).
