I have installed AppImage v1.6.8 on openSUSE Slowroll and it will not open.
Thanks for reporting this, and sorry for the trouble. We reproduced it on openSUSE Tumbleweed, which Slowroll follows, and it’s a problem in how our AppImage is packaged, not anything on your side.
What’s going on: the AppImage carries its own copy of a Wayland library, and that copy is older than what openSUSE’s current graphics drivers (Mesa 26) need. When RcloneView starts, the graphics driver can’t load next to that old library, so the app can’t set up its window and quits right away. It happens in both Wayland and X11 sessions. Our AppImage packaging hasn’t changed since 1.5. What changed is the Mesa update on Slowroll, and the older 1.5 AppImages are built the same way, so they’d most likely run into it as well.
Workaround until the fixed build is out: unpack the AppImage, remove the bundled Wayland library, and start the unpacked app. In a terminal, in the folder where the AppImage is:
./RcloneView-1.6.8-x86_64.AppImage --appimage-extract
find squashfs-root -name 'libwayland-*' -delete
./squashfs-root/AppRun
This creates a squashfs-root folder. You can move it somewhere permanent (for example ~/Applications/RcloneView) and start RcloneView with AppRun inside it. Unpacking doesn’t need FUSE, so this also gets around the next point.
If double-clicking the AppImage does nothing at all: AppImages also need FUSE 2 to run directly. If running it from a terminal prints “AppImages require FUSE to run”, install it with sudo zypper install libfuse2.
We’re changing the AppImage so it uses your system’s copy of this library, and we’ll post here when a fixed build is available. If the workaround doesn’t work for you, please run the steps above in a terminal and paste the output here.
Awesome, I was going to make a similar post but I can confirm that the workaround also worked for me in all scenarios. In my case I use a laptop with a discrete NVIDIA GPU and an integrated AMD GPU. On AMD graphics, when I launch the AppImage the window opens but remains black, then I have to Ctrl+C to quit it. Curiously, if the NVIDIA graphics is set to primary, then RcloneView works perfectly without the need for a workaround.
Maybe someone else has reported issues with AMD drivers? If it helps with anything I can share some logs:
AppImage (1.6.8 x64) log: Gtk-Message: 00:26:31.682: Failed to load module "xapp-gtk3-module"** (rclon - Pastebin.com
eglinfo: EGL client extensions string: EGL_EXT_client_extensions, EGL_EXT_device_bas - Pastebin.com
Thanks for your hard work in making RcloneView awesome!
Thanks for confirming, and for the logs. This isn’t an AMD driver problem. It’s the same issue Jeff ran into: the AppImage bundles an older copy of a Wayland library that clashes with newer Mesa drivers. The workaround removes that copy, which is why it fixed every case for you. On your laptop it shows up as a black window instead of a crash, but the cause is the same.
The fix is done: the AppImage no longer bundles that library and uses your system’s copy instead. It will be in the next update, and we’ll post here when it’s out. Until then, the unpacked copy from the workaround is the way to go.
