Batch Job Processing – Chain Multiple Jobs into One Flow
:page_facing_up: Description
Introduce a Batch Job feature that allows users to group and execute multiple RcloneView jobs — sequentially or in parallel — as part of a single operation.
This enables automated workflows like:
  • Copy → Sync → Purge
  • Move to Cloud A → Backup to Cloud B
  • Delete temp → Copy fresh content → Notify on Slack
A Batch Job acts like a “playlist” of jobs, preserving their order and type, with unified status tracking and error handling.
:hammer_and_wrench: Usage Scenarios
  1. Daily Production Archive
    • Copy from local drive → primary cloud (Dropbox)
    • Move processed files to cold storage (Backblaze B2)
    • Purge temp folder after success
  2. Multi-cloud Sync with Cleanup
    • Sync main documents folder to OneDrive
    • Delete legacy files from Google Drive
    • Copy same data to a USB path as local backup
  3. Safe Transfer with Final Cleanup
    • Copy → Verify (planned) → Purge source
Each step would execute in order and report its result individually, with the entire batch treated as a single unit.
:test_tube: Reference UI
:warning: Limitations to Overcome
Current Limitation Clarification
RcloneView runs single jobs independently No native support for sequential/conditional job execution
No “Job dependency” logic yet Requires UI and backend to manage job groups and order
Error handling between jobs unclear Need toggle: continue on error vs. stop on failure
:date: Roadmap (Vision)
  • :white_check_mark: Design Batch Job structure (with name, description, job list, run mode)
  • :puzzle_piece: Support manual run + per-job status tracking
  • :repeat_button: Add “Run jobs sequentially” vs. “Run in parallel” toggle
  • :stop_sign: Option: Stop batch on first failure or continue regardless
  • :tear_off_calendar: (Future) Schedule Batch Jobs just like normal jobs
  • :outbox_tray: (Future) Export/Import batch templates (.json)
:woman_raising_hand: Want this feature?
Upvote this post if you want to create powerful, multi-step workflows inside RcloneView using Batch Jobs!
Which combinations of jobs would you automate? Share your ideas below :backhand_index_pointing_down:
