I am syncing 22tb of mainly documents and videos from AWS bucket to Box.. My internet speed is 1000 mbs up and down and am using a computer with 32mb of ram to run rclone view. What setting should I use to optimize the synchronization.
Thanks for the details on your setup.
We’ve picked this up together with your other thread about the error you’re hitting on the same S3 to Box transfer, and both are logged on our side and being looked at.
We’d rather not hand you a settings recipe before we understand why the transfer is failing at start, since the two are likely related — a 22-23 TB transfer to Box runs entirely through your machine, and the transfer/checker concurrency is exactly the kind of thing that shifts once we know what’s happening. So we’ll come back with a concrete recommendation rather than a guess.
One quick confirmation in the meantime: is the machine 32 GB of RAM (your post says “32mb”)? That figure matters for the tuning advice.
