Hi I’ve just started using RcloneView, so I apologise if my question is too much of a ‘newbie’ one. I am using Rclone to sync folders on my Windows 11 25H2 PC with backups on a Debian server on my home LAN. In RcloneView, the 4 local disks show as C,D,E and F as expected, but only D, E, and F allow me to get to the root folder and select a subfolder. For the C drive, I only get my User folder, called C:\Users\mikej. No up arrow or way to edit (that I can see!). This is a problem as I have folders there that I’d like to back up. Am I missing something very obvious?
Hi,
Thank you for trying RcloneView!
You can navigate to any folder by clicking directly on the path text displayed at the top of the file browser. This will allow you to jump to C:\ or any other folder you’d like to select.
Hope that helps!
Best regards,
RcloneView Support
