Edit (and import/export) filtering settings on a program level, rather than on a job level
Is there any way to edit (and import/export) filtering settings on a program level, rather than on a job level?
Hi Michael,
Thanks for the suggestion! We’re working on a preset feature that will allow you to save your filter settings as a preset and reuse them when creating new jobs. While it won’t support file-based import/export, you’ll be able to manage filter configurations at the program level through saved presets.
We’ll keep you updated on the progress.
Best regards,
RcloneView Team
Wow, thanks. This would be great!
Hi there, Any news on this preset feature?
If you don’t mind that it is a beta version before the official release, I will send you the download link. Do you use RcloneView on Windows?
Hi Michael,
The filter preset feature is now available in version 1.4.17. You can save your filter settings as presets and reuse them across different jobs.
Here are the download links:
Please give it a try and let us know if you have any feedback!
Best regards,
RcloneView Team
