On your website it says “Connect to external Rclone daemons across different environments and manage remote cloud storages effortlessly in separate RcloneView windows.” I just installed rclone on fast Ubuntu server, but cannot connect your app. Could you please provide some kind of information on how to safely connect to a server running a rclone daemon? ports, SSH handling, user, passwords, etc. On you connection input screen it only mentions the localhost.
By default, the rclone remote control daemon (rclone rcd) uses HTTP. To secure it, you can enable HTTPS with a TLS certificate and add authentication. For detailed instructions, refer to the official documentation:
On a production system, you might already have a configured certificate, in which case you can simply open the rclone port (default: 5572) using ufw. However, I’ll assume you’re running rclone on an Ubuntu machine that isn’t set up as a production server with certificates. Instead, we’ll use SSH tunneling for security.
Step 1: Run rclone on Ubuntu
Start the rclone remote control daemon with the following command:
rclone rcd --rc-addr=localhost:5572 --rc-user=admin --rc-pass=password
- Replace admin with your desired username and password with your chosen password.
Step 2: Set Up an SSH Tunnel on Windows
From a Windows command prompt, create an SSH tunnel to forward traffic securely:
ssh -N -L 5572:localhost:5572 user_id@ubuntu_ip_address
Replace user_id with your Ubuntu username and ubuntu_ip_address with the IP address of your Ubuntu machine.
The -N flag prevents an interactive shell, running the tunnel in the background. You’ll be prompted to enter the password for user_id.
Note: If you want the tunnel to persist without keeping the terminal open, add the -f flag (e.g., ssh -f -N -L …).
Step 3: Configure a New Remote in RcloneView
On your Windows machine, use RcloneView to connect to the remote daemon:
Open the Connection Manager and click New Connection.
Configure the new rclone connection with:
- Address: http://127.0.0.1:5572
- User: admin (or your custom username from Step 1)
- Password: password (or your custom password from Step 1)
- Click Test Connection to verify it works, then click Save.
Notes
Since we’re using SSH tunneling, TLS certificates aren’t required for rclone rcd in this setup—the tunnel encrypts the connection.
Ensure rclone rcd is running on Ubuntu before starting the SSH tunnel.
Hope this helps! Let me know if you have any further questions.
