Hey, awesome looking program…i wonder if you could help please…i am trying to set up a webdav connection to premiumize…i ha e filled in my credebtials on the new connection section but it keeps saying failed to connect…can you help please…
Hello Darrenigoddard,
Thank you for using RcloneView!
To resolve the issue with your WebDAV connection, please check the following:
- Correct WebDAV URL
The WebDAV URL provided by Premiumize is usually:
https://webdav.premiumize.me/
Please ensure you are using this URL. - Credential Verification
Double-check that the username and password you entered match your Premiumize account login details. - Port Number
WebDAV typically uses port443(for SSL connections). If you need to specify the port, ensure it is set correctly. - How to Set Up WebDAV in RcloneView
- Create a new connection and select WebDAV as the connection type.
- Enter the URL, username, and password.
- Ensure all details are entered correctly, then try to connect.
- If the Problem Persists
If the issue continues after trying the above steps:
- Share a screenshot of your WebDAV configuration screen.
- Include the error message you are seeing.
With this information, we’ll be able to better understand the problem and provide a more precise solution.
Thank you!
Best regards,
RcloneView Support Team
Thankyou for that i will try again…
