Help with RCloneView GDrive->external SSD
Newbie to rclone here :woman_technologist:
I’m having troubles setting up a backup of my GDrive on my MacBook air M1. I have made a 200 GB volume APFS container on my Samsung T7 SSD, and I’m trying to follow this guide: https://rcloneview.com/support/blog/offline-first-sync-external-drive-rcloneview
But I dont know where to enter the path to the SSD. I tried to make it as: New Remote → Local File System, but now I just have a path that leads to the mac home folder. Somewhere in the setup it also made a location called RcloneView that in FInder looks like a disk that can be ejected.
I understand that rclone will use some space on my laptop cashing data before transfering to the SSD, but how do I set up the correct end destination?
Thanks in advance :folded_hands:
After seeing your post on r/rclone, we identified the issue and have implemented a fix. RcloneView now automatically detects any new volumes under /Volumes and displays them in the left panel under the Local tab.
Please try the following version and let us know if it resolves the problem:
https://downloads.bdrive.com/rclone_view/builds/RcloneView-1.1.517.dmg
Thanks for using RcloneView!
That worked! Thanks a lot :sparkles:
