Hello,
thanks for that great app. I am testing it out right now. How can I connect to my rclone encrypted folder? Did I perhaps overlook the option?
Hello,
Hello Sweep,
Thank you for using RcloneView!
Regarding your question about connecting to an encrypted remote, please consider the following:
rclone.conf).rclone config.rclone.conf file is being used by RcloneView.rclone.conf file in the RcloneView settings menu if necessary.Feel free to reach out anytime if you have further questions or need additional assistance.
Best regards,
RcloneView Support Team
Sure! Here’s a rephrased version:
Hi there,
Thanks for the help! I was a bit confused earlier because my rclone setup is on a server, and I wanted to access the remote from my MacBook. To do that, I set up the remotes again on my MacBook. However, I just copied the rclone.conf file from my server to my MacBook, and now I can see my encrypted remote.
Thanks again!
Hello Sweep,
Thank you for your feedback! We’re glad to hear that you resolved the issue.
Copying the rclone.conf file from your server to your MacBook was a great solution, and it’s wonderful to know that you can now access your encrypted remote.
If you have any further questions or need assistance in the future, feel free to reach out anytime.
Best regards,
