Issues with expanded Terminal
Hi,
I’m on Windows 11.
When the Terminal within RcloneView is expanded first, the “Add job” window (from Home => + Add Job => Add Job) doesn’t open up properly. The windows of other functions work without issue.
Another issue when the Terminal within RcloneView is expanded happens when using “Restart Embedded Rclone” from the options. RcloneView then freezes and I didn’t find any other solution than to end the task from the Task manager.
Hi papaya241,
Thank you for reporting this. We were able to reproduce both issues — the “Add Job” window not opening properly and RcloneView freezing when restarting embedded rclone while the terminal is expanded.
The fix will be included in the next release.
Thanks again!
Hi papaya241,
The fix for both issues is now available in version 1.4.17:
Please let us know if you run into any other issues!
Best regards,
RcloneView Team
