No way to set rclone.conf password
When trying to connect to the default “embedded Rclone”, I get connection failed error. My config file is encrypted. The popup says I should set the config passowrd in Settings:
However, there’s no option to set config password in the settings.
I’m using the latest rclone and rcloneview versions. Win10.
Please scroll down to the ‘Embedded Rclone’ section, where you will find the Rclone config password field.
Oh, I’m a dumbass. My bad. Thanks for the quick reply.
It looks like the rclone config password gets saved in a plain text file on your PC, this is really unfortunate. Means I cannot use it and will have to stick to rcd. I know this is early release, but please at least put a warning into the settings at least. This is a huge no-no for obvious reasons. Especially when we have flutter_secure_storage
Thanks for pointing this out.
You’re right — saving the rclone config password in plain text isn’t great. We’re already working on encrypting it, and it’ll be fixed in the next release.
Appreciate you letting us know!
