Rclone Mount in Windows
Hi all
I have mounted my Drime drive and mapped it as a drive (U:) - but I am unable to run .exe files from it. It says I do not have permission. Do you know how I can fix it?
Thanks
How do I connect with Drime Drive?
Make sure you have the latest RClone View installed as Rclone now supports Drime with their latest build.
Hi,
Apologies for the late reply! Thank you for reporting this.
The current version does not have options to specify executable file permissions, which is why you’re seeing that error when trying to run .exe files from the mounted drive.
I will be posting an updated version that includes the necessary option fields to address this. Sorry for the confusion, and please watch for the update!
Best regards,
RcloneView Team
Hi MoneySings,
Version 1.4.17 now includes options to specify file permissions for mounted drives, which should resolve the issue with running .exe files from your Drime mount.
Please give it a try and let us know if it works for you!
Best regards,
RcloneView Team
