RcloneView 0.8 – Release Notes
Release Date: July 2025
Platforms: Windows, macOS and Linux
RcloneView 0.8 is a major update focusing on performance stability, sync job usability, error handling, and extended cloud provider support. This release also includes key improvements to user interface behavior and compatibility.
New Features & Enhancements
- Unified Transfer & Completed Panels: Merged into a single view for streamlined job tracking.
- Mount Dialog Enhancements: Added a
Reloadbutton and adjusted height for usability. - Remote Tab Dragging: Drag remote tabs between panels for flexible UI management.
- License Handling Improvements: Better error reporting and license transfer options when registration fails or device access is lost.
- Dropbox Business Support: Fixed alias visibility issues and improved upload error handling.
- Sync-to-Job Flow: Automatically opens Job Manager after saving a sync task.
- Scheduling History Logging: Error logs for failed scheduled jobs now appear in History.
- Disable Sync Completion Popups: New option to turn off sync completion notifications.
UI & UX Improvements
- Explorer Panel Double-Click Fix: Fixed remote not opening on job double-click.
- Left-Aligned Job Icons & Names: Improved layout consistency.
- About Dialog Dark Mode Fix: Resolved visibility issues in dark mode.
- Tap Behavior Update: Prevents entire text selection when tapping fields.
- Pre-Filled Rename Field: Displays current filename during rename.
- Main Menu Styling: Enhanced contrast for icons and text.
- Custom Uninstall Icon: Added a branded uninstall icon.
- Log File Cleanup on Startup: The application now deletes the previous log file when starting, ensuring cleaner logs for each session.
Bug Fixes
- DB Upgrade Blocker: Fixed a startup crash related to database upgrade failure.
- Compare View Fixes: Corrected file count display and source/destination selection bugs.
- Job Import/Export Issues: Improved UX and prevented duplicate job names on import.
- Mount Drive Conflict: Prevented drive letter duplication on mount.
- Rclone Execution Path: Now always runs from the system root directory.
- Trailing Slash on Folder Delete: Ensures accurate deletion of directories.
- Network Loss Handling: Popup message now shown when network disconnects occur.
- Windows Remote & Folder Refresh: Fixed remotes not appearing after CLI add and folders not refreshing after file deletion.
- Multi-File Delete Logging: All deleted files now logged in the completed list.
- Dry Run Freeze Fix: Resolved app unresponsiveness when viewing many file results.
- KDE Plasma Tray Icon Support: Fixed tray icon display issues when running on KDE Plasma desktop environment.
Localization & Compatibility
- Japanese Localization: Added missing Japanese localization files.
- German Translation Fix: Resolved compilation error due to incorrect translation strings.
Thank you for your continued feedback and support. RcloneView 0.8 focuses on making your cloud file management faster, more reliable, and more intuitive than ever.
— The RcloneView Team
