RcloneView 1.7 – Release Notes
Release Date: November 2026 · Platforms: Windows, macOS, Linux
Full release notes: English · 한국어 · 简体中文 · 繁體中文 · 日本語 · Deutsch · Español · Français · Bahasa Indonesia
Download: Download page · Windows 1.7.14 · macOS 1.7.7 · Linux 1.7.3: AppImage x86_64 / aarch64, deb x86_64 / aarch64, rpm x86_64 / aarch64
RcloneView 1.7 takes Batch Jobs out of beta and adds import and export of remotes, with an undo for a recent import. Several settings that rclone had been quietly ignoring now do what they say — a job’s retry count, the delete timing of a sync, one-letter and local-disk Custom flags, and the options of batch Check and empty-folder steps — so please read the first section before upgrading. This release also lets you run a job straight from its Dry Run preview, redesigns Mount Manager and the mount window, adds Detect renamed files for Sync, shows start and completion times in the Transfers tab, and hides system files in the explorer by default. Uploads to Google Drive now stop at the daily limit, macOS mounts that hang while unmounting no longer hold up the app, and very large previews no longer freeze it. Alongside those, it fixes a long list of problems in transfers, mounts, the explorer, multiple windows, licensing, and the Linux packages.
Please Read Before Upgrading
Batch Jobs now need PLUS, with a 7-day trial. Batch Jobs are out of beta and part of PLUS. On a free license, adding, opening, editing, duplicating, previewing, and running a batch now ask for PLUS (until now only scheduling did). Batch Jobs open for 7 days on this computer from the first time this version runs. When the trial ends your batches are not deleted: they stay in Job Manager, locked, and open again once a PLUS license is registered.
Importing and exporting jobs and remotes needs PLUS, with a 7-day trial. Job Import and Export in Job Manager, free until now, are now part of PLUS, as is the new import and export of remotes in Remote Manager. On a free license each opens for 7 days from the first run of this version. Undo a recent import and Where are my remotes saved? stay available on every license.
Sync and Copy jobs now try again after a failure. A job’s Retry the entire operation if it fails this many times setting (3 by default) and
--retries/--retries-sleepin Custom flags never did anything: rclone reads them only on the command line, so every job ran exactly once. RcloneView now retries a failed Sync or Copy job itself, by the same rules as the rclone command line: only when rclone considers the errors retryable and none is fatal, up to that number of attempts in total, waiting--retries-sleepbetween attempts. Cancelled runs and runs stopped by a rejected sign-in are not retried. History, notifications, and email report the run once, after the last attempt. This changes what existing jobs do. A failing job now takes longer to report it, and a run that failed because of a passing problem may now complete. To keep a job to a single attempt, set the value to 1. Bisync jobs are not affected. -
Uploads to Google Drive now stop at the daily upload limit. Google Drive accepts about 750 GB of uploads per account per day. rclone treated that limit like an ordinary rate limit and kept retrying, so a large job could stay “running” for days without uploading anything. The bundled rclone now stops as soon as the limit is reached, and the job ends with a message explaining it. Run the same job again once the limit resets (usually within 24 hours); files already copied are skipped. This changes what long Google Drive jobs do: they now end with an error at the limit instead of waiting it out.
The explorer now hides system files and leaves them out of its copies. A new setting, Hide system files in Settings → Interfaces & Notifications, is on by default. It hides
$RECYCLE.BIN,System Volume Information,desktop.ini,Thumbs.db,pagefile.sys,hiberfil.sys,swapfile.sys,.DS_Store,.Spotlight-V100,.Trashes, and.fseventsdin the explorer, and leaves them out of copy and paste, drag and drop, upload, and download in the explorer. Jobs, Compare, moving, and renaming are not affected. If you copy whole drives in the explorer and need those files, turn the setting off. Job filters also get a System files group, off by default. -
Custom flags and batch options that did nothing now take effect. These were sent to rclone in a form it discards. They now work, which changes what jobs and batches using them do:
--delete-beforeand--delete-during(Custom flags or a batch step’s delete-timing chip): a sync always deleted after transferring. A job or step with more than one of--delete-before,--delete-during, and--delete-afternow refuses to run, as rclone does. -
One-letter flags such as
-c,-u, and-Mwere dropped silently, and one after a flag that takes no value was read as that flag’s value. They are now expanded to their long names; unknown ones are left out with a warning. -
--copy-links(-L),--skip-links,--one-file-system(-x), and--skip-specialsnow apply to the local source or destination of the job (on a cloud side they do nothing, and the warning says so). With--copy-links, the files symbolic links point to are now copied. -
--metadata-include,--metadata-exclude,--metadata-filter, and their-fromforms. -
A batch Check step’s
--one-way,--download,--size-only, and--fast-listchips and its Additional flags.
Flags rclone reads only from the command line, such as
--error-on-no-transferand--progress, now show a warning that they have no effect. Please run affected jobs and batches once with Dry run before letting them run on a schedule. -
Batch empty-folder chips now decide what happens to empty folders. The
--create-empty-src-dirsand--delete-empty-src-dirschips did nothing: Copy Folder and Sync steps always recreated empty source folders, and Move steps always did that and removed the source folders they emptied. Each step now does this only when its chip is on, in already-saved batches too. This changes what existing batches do. If you rely on empty folders being copied, or on a Move step cleaning up emptied folders, turn the chip on. Rename steps always move the whole folder, and their--delete-empty-src-dirschip has been removed. -
A batch Delete step with
--rmdirsnow removes empty folders.--rmdirswas ignored when the batch ran; only the preview showed folders being removed. The step now also removes the empty folders left under its path, keeping the step’s folder itself. Include and exclude rules apply, and folders that still hold files (e.g. newer files kept by--min-age) are left alone. The Cleanup history template uses this. If you expect empty folders to stay, remove--rmdirsfrom the step. -
Batch steps that used to pass can now fail. A Check step counted only files missing on one side. Files whose contents differ, and a check that could not run at all, now fail the step, so its Error policy decides what happens next. The step also gains the outputs
differanderror_files. A step that uses the output of an earlier step that produced none — e.g.{{step1.differ}}after step 1 failed — used to run with that text as written, creating a folder with that name; it now fails with Not run and the reason. -
Do not go back to 1.6 after this update. The database format changes again (to record transfer completion times, mount failures, and each mount’s kind and VFS settings). If an earlier version opens the database afterwards, it deletes it and starts empty: jobs, batches, job history, saved mounts, and filter presets are lost. Remotes and settings are not affected. If you may need to go back, keep a copy of
rclone_view.dbfrom the Database folder shown in Settings before updating.
Data Loss and Security
A Batch Check Step Passed When Files Differed: A Check step treated files with different contents as matching, and a failed check (remote error or timeout) as finding no differences. A batch that checks a copy before deleting or moving the source could therefore remove source files whose copy did not match or was never checked. The step now fails in both cases. If you have a batch that runs a Check step before a Delete, Purge, or Move step, make sure the destination holds complete copies of what was removed.
A Leftover Drag Could Copy or Move Folders on the Next Click: A click with a slight mouse movement starts a drag. When another window (a provider’s sign-in page, a secondary window, a system dialog) took the mouse before the button was released, the drag stayed alive and the next click — often in the other pane — dropped it, copying or moving the folders open in the first pane. It was seen after signing in to a provider, entering a license key, editing a remote, and adding S3, B2, or Mega remotes. Such a drag is now ignored. If a transfer you did not start appeared in the Transfers tab after one of these steps, check both folders.
A Batch Step Changed to Rename Could Move Only Part of the Folder: Changing a step’s operation kept the old operation’s hidden filter and transfer values. A Move step with a Min age filter changed to Rename kept the filter, so only matching files were moved to the new name. Changing the operation now keeps only the options the new one offers, and Rename never applies filters, including in saved batches. If you have a Rename step that was once a different operation, check that nothing was left under the old name.
Highlights
Batch Jobs Leave Beta: The Beta label is gone, and batches gain:
Retry Failed Steps — after a failed run, continue from the failed step, passing on the outputs of finished steps. A failed run can also be retried from the batch’s history: finished steps are skipped, earlier steps whose output is needed run again, and the step list is shown before anything starts.
Run in background — the run window no longer blocks the app. Follow the batch in the Transfers tab; a message says when it has finished or failed. Pressing Run on a running batch reopens its window, and manual and scheduled runs of the same batch no longer overlap.
Update existing files only — a new option for Copy steps that copies only files that already exist at the destination. The new Files-on-Demand (Offline Cache Sync) template uses it to keep a local offline folder and a cloud folder in step.
Import and Export Remotes (PLUS): Remote Manager has a new menu for backing up and restoring remotes. Import remotes from a file… reads an rclone configuration file and shows which remotes are new, unchanged, or have the same name but different settings; you choose which to add. For a taken name, pick Keep mine (default), Use imported, or Keep both (imports as e.g.
name-2); See what’s different lists differing settings with secrets hidden. Files encrypted with a configuration password are refused with an explanation. Export remotes to a file… can leave out passwords and tokens so the file is safe to share. Undo a recent import restores the remotes an import changed, from a copy kept in the app’s secure storage. Where are my remotes saved? shows and copies the configuration file’s path. Import and undo are unavailable while connected to an rclone RcloneView did not start; an encrypted rclone configuration stays encrypted. -
Mounts That Hang While Unmounting No Longer Hold Up the App (macOS): rclone can get stuck waiting on a system unmount command that never finishes. Unmounting then took 30 seconds and failed, Unmount all took about a minute, and quitting left rclone and that command running. Unmounting now falls back to the system’s own unmount after about 12 seconds and updates the list at once, and Mount Manager shows progress. On quitting, a stuck rclone and the unmount commands it started are stopped — those processes only, by process id. On every platform, while rclone has not finished an earlier mount request, new mounts wait behind it. The app now says rclone is busy with another mount, stops sending new requests until it answers, and offers Restart Embedded Rclone, telling you first how many mounts and transfers a restart will stop.
Large Previews No Longer Freeze the App: A dry run listing hundreds of thousands of lines froze the app. Now the Wizard lists up to 500 rows (totals still count everything), a batch’s detail log keeps up to 5,000 lines, and the error dialog shows up to 100 error lines. Cancel stops a running job, Wizard, or batch preview at once; a preview gives up only after rclone has sent nothing for five minutes. Paths containing
{or}no longer break preview lines. Also fixed: a loading overlay that could stay on screen and block every click, and Remote Manager repeatedly asking every remote for its details.
New Features and Improvements
Run Straight From a Dry Run: When a job’s Dry Run finishes, the preview offers Run next to Cancel, starting the same job with the same filters and options the preview saw. If the job is already running, you are asked first. In the one-time Sync/Copy dialog the preview uses the form as it is, without saving it.
Mount Manager Redesigned: Mounts are listed in a table with Status, Source, Mount point, Method, and Auto columns, plus a summary such as 5 mounts · 3 mounted · 1 need attention. Mounts needing attention come first, and columns are sortable. Error rows show rclone’s reason and when it failed, with a Remount button; an automatic mount that fails at start is recorded the same way. Disconnected marks an auto mount that is not mounted (e.g. after rclone restarted). Each row’s ⋯ menu offers Open folder, Copy path, Edit, Duplicate, and Delete. Success messages after every mount, unmount, or delete are gone; failures are still reported.
Mount Window Redesigned: Choose between two kinds: Standard, for documents and photos, and Media streaming, which fills in cache and read-ahead values so Plex, Jellyfin, and video players play without stuttering, and mounts read-only. Settings are grouped (Basic, Cache, Playback, Folder listing, Writing, Permissions, Other), and every rclone VFS option plus
--attr-timeouthas its own field, showing rclone’s current value in grey when empty and validated the way rclone does. A field also set in Custom Flags says Overridden by Custom Flags. The window shows where the mount will actually appear (and, on Windows, the drive’s name in Explorer), and Browse is available for the remote path and, on macOS and Linux, the mount location. Refresh new files (every minute up to every hour) shows files added on the remote without waiting for the folder cache to expire — useful for SFTP or WebDAV. For Media streaming, parallel reads (--vfs-read-chunk-streams) default to 8 for PikPak, Proton Drive, and Filen, and 0 for others; wrapping remotes such as Crypt are judged by the remote they wrap. -
Detect Renamed Files: One-way Sync jobs have a new Detect renamed files option (
--track-renames), also a chip on batch Sync steps: renamed or moved source files are moved on the destination instead of uploaded again. Without a shared hash (e.g. Crypt, SMB), files are matched by name, size, and modification time. -
Start and Completion Times in the Transfers Tab: New Started at and Completed at columns, with the full date in a tooltip. Completion times are saved across restarts (transfers before this update have none).
Waiting Between Retries Shown in the Transfers Tab: While a job waits to retry, its last row shows Retrying in 30s, counting down, with an ✕ that cancels the whole run.
Clearer Connection Errors in the Wizard: For WebDAV and SFTP, the Verify step names the problem — Sign-in failed, Access denied, WebDAV folder not found, Cannot connect to the server, Server not found, Secure connection failed, The server’s identity has changed — and says what to check, with rclone’s message under Show details. Failing to reach the server is now shown at the Connect step.
Fixing a Sign-In Failure From a Mount or Job: Since 1.6, a remote whose sign-in was rejected is not contacted again until you press Retry, but that button was only in the explorer. Mounting or running a job on such a remote now explains that RcloneView did not connect, gives the earlier reason, and offers Edit Remote and Retry; once sign-in works, the mount or job carries on. The Sign-in failed badge in Remote Manager opens the same window.
Google Photos as a Source: Google Photos only lets RcloneView read photos uploaded with the remote’s own client ID, so copying a library filled from the Google Photos app transfers nothing. The job dialog, Wizard, and batch editor now say so, with a link to Google Takeout.
Your Own Client ID Recommended for Google Drive: A Google Drive remote without a
client_iduses rclone’s shared client ID, which can be slow or fail with 403 errors. New Remote, Edit Remote, the Wizard, and the mount window (for Media streaming) now say so, with a link to How to create your own client ID. Saving without one still works; service-account remotes are not affected. -
Retry a Cancelled Transfer: A copy, move, upload, or download cancelled in the explorer now has a Retry button; files already copied are skipped. A transfer cancelled while still checking files is now shown as Canceled instead of No Changes or Success.
Transfer Groups Stay the Way You Left Them: An expanded group no longer collapses when the filter changes or another transfer finishes. A new setting, Show transfer groups collapsed, is off by default.
Remote Cards in the Explorer: Remote cards now have an Edit button next to Open and the same storage chart as Remote Manager, with Free in green. Long names are shortened with “…”.
Finding the rclone Log: Settings → Embedded Rclone has a new Open log folder button. On Windows, the default log folder is now your actual Documents folder (including when it was moved to OneDrive) instead of always
%USERPROFILE%\Documents. A log folder you set yourself is not changed. -
Compatible DNS Mode (macOS): With iCloud Private Relay on and a remote using plain HTTP (e.g. Mega), rclone on macOS can stop starting new tasks, so mounts and previews never finish. RcloneView now detects and explains this, with a button to restart rclone in the new Compatible DNS mode (Settings → Embedded Rclone, off by default). In that mode,
.localnames and names only your VPN knows are not found. -
Opening Settings With ⌘, (macOS): ⌘, now opens General Settings when no dialog or menu is open.
Start-Up Problems Explained: A missing bundled rclone now shows Rclone executable not found with advice to reinstall or allow RcloneView in your antivirus. On Windows, an error before the window opens is shown in a message box with a log location, and starting RcloneView while an earlier copy is hung now says so and explains how to end it.
What’s New in RcloneView Mobile 1.1: The RcloneView Mobile window now shows the mobile 1.1 update — streaming, cloud-to-cloud copy and sync, and freeing phone space after photo backup, all part of Plus — with a short video, QR codes for Google Play and the App Store, and Send remotes to phone. It opens once by itself after the update; Help → RcloneView Mobile still opens it.
Bug Fixes
Jobs, Batches, and Transfers
Running a Job Again While It Was Running: Run → Proceed on a running job cancelled it but never started the new run, and a “Job N error” dialog then closed instead of Job Manager. The app now waits for the old run to stop, then starts again, and records the cancelled run as Canceled.
Closing a Dry Run Error Closed Job Manager: Closing a dry run’s error dialog also closed Job Manager or the Sync/Copy dialog underneath it.
The Folder Depth Error Closed by Itself: With Don’t process folders over this depth on and the box empty, the error flashed and closed as if the job had started.
Empty rclone Windows During Dry Runs and Scheduled Bisync (Windows): Every dry run opened an empty console window (closing it stopped the dry run), and short bisync runs flashed one even with
--no-console. -
Short Bisync Runs Ran Twice: A bisync finishing in under 5 seconds was run a second, real time to collect error details, even when it succeeded — transferring files without showing them and resyncing again with resync on. The second run now happens only after a failure.
A Stray Comma Made a Schedule Run Every Time: A schedule field ending in a comma (
5,) was saved as “every”. Empty parts are now removed (1,,3becomes1,3). -
Monthly Schedules in the Preview: Upcoming runs showed only 3 runs for a monthly schedule instead of 10.
Scheduled Batches Overlapped: A batch whose run outlasted its interval ran again immediately or in parallel. Schedule times that pass during a run are now skipped.
Jobs Changed Through the Web Server: Job changes via the web server’s API did not update schedules until restart.
Bots Said “Started” When Nothing Started: The Telegram, Slack, and Discord bots answered Started job even when the job did not start. They now say why.
Duplicate Job Names: Duplicate could reuse a name from another connection, and a copy of
Job (1)was namedJob (1) (3). Names differing only by leading or trailing spaces could both be saved. -
Batch Dry Runs Said “No Changes”: Previews of batch Delete, Purge, and same-remote Move steps reported no changes. A cancelled batch dry run now says how many steps were not checked.
A Cancelled Batch Was Saved Twice: Once as cancelled and once as failed.
--dscpand--metadata-setin Custom Flags:--dscpis now read as rclone reads it (0–63 or a name such asAF21), and--metadata-setkeys are sent in lower case. -
Bandwidth Limit Between Two Local Folders (macOS): Local-to-local batch Copy or Sync steps ignored their bandwidth limit; they now copy through rclone when a limit is set.
Copied Files Shown as “No Changes”: Small files rclone 1.75 had copied were shown as No Changes.
Uploads Stuck at “Queued”: Overwriting a file of the same name stayed at Queued and 0% for the whole upload.
File Names Cut Short in Transfer Details: A file name starting with the destination folder’s name lost that part (
support-sitemap.xmlshown as-sitemap.xml). -
Backup Copies Listed as Transferred: Files moved into a sync’s backup folder were listed as transferred on storage without server-side move.
Folder Name Repeated in the Source Column: Failed or cancelled folder transfers showed
…/big/big/big. -
Earlier Transfer History Disappeared: rclone restarts job numbering at 1, and a new run with the same number deleted the earlier run’s transfer records.
Maximizing the Transfers Panel: Restoring it switched both explorer panes back to their first tab.
Mounts
Mounted Drives Marked as Unmounted (Windows): While rclone was busy and did not answer, still-mounted drives were recorded as unmounted.
Unmount Failures From the Tray: A failed tray unmount now shows a notification, and Unmount all checks whether drives are actually gone instead of showing an error when rclone is slow.
Empty Folders Left Behind by a Failed Mount: The mount-point folder RcloneView created is now removed; pre-existing folders are left alone.
Absolute Paths on a Named Local Remote (macOS and Linux):
/home/me/xwas mounted inside your home folder as an empty folder. RcloneView now checks which folder exists, or fails with Folder not found. -
More Mounted Local Remotes Listed as “Configured” (Windows): Remotes named
local, drive-root or relative-path mounts, and aliases likeloc:C:were listed as configured while mounted. -
Mount Folder Name Already in Use (Windows): Mount Manager now says where the name is taken and offers a free one.
Empty Mount Point Saved (macOS and Linux): A mount could be saved with an empty mount point, possibly
/. A folder name is now required.
Explorer, Compare, and Filters
Unreadable Local Folders Looked Empty: They are now shown as not loaded, with advice on disk access and permissions.
The Folder Picker Showed Only “/”: When a remote’s top folder could not be read, pickers now show Couldn’t load this folderwith Retry.
The Folder Picker Picked the Previous Remote’s Folder: Switching remotes quickly could select a folder of the previous remote.
Typing a Path on the Local Disk Tab (Windows): After typing a path on another drive, Compare, Sync/Copy, and Job Manager used the wrong drive and failed with “directory not found”.
New Folder Reported Success When Nothing Was Created: On B2 and S3-compatible storage, which cannot keep empty folders, the Log now shows Failed with an explanation instead of “completed successfully”.
Renaming Duplicates: Ran without your rclone config and global flags, and reported success on failure.
The Folder Tree After Rename or New Folder: Could show old contents, collapse folders, or stay loading.
Compare Listed Filtered-Out and Empty Folders: Folders whose files were all excluded, and intermediate folders with no files, are no longer listed.
Compare Copy Never Finished: When rclone could not be reached, rows never completed; after three failed status checks they are now marked failed.
Choosing a Folder of an Alias Remote in Compare: The picker showed an empty tree, and the folder came back under the target remote’s name.
“Others” Stayed Checked in Filters: Removing the only rule under Others left it checked with nothing under it.
Remotes and Signing In
Saving a Remote Interrupted Other Remotes: Adding, editing, or deleting a remote cleared rclone’s cache for every remote, interrupting transfers and mounts. The whole cache is now cleared only when another remote depends on the changed one.
Changes to the Configuration File Were Missed: Outside changes to
rclone.confwere missed in several cases (file created after start, recreated, after Update Rclone), and concurrent changes could be lost. -
Sign-In Failures Shared Between Connections: A remote with the same name on two connections shared one sign-in record. Each connection now keeps its own.
Oracle Object Storage Private Key Not Found: When
key_fileis a bare name or relative path, the error now explains how to fix it.
Wizard
Running Again After a Failure Saved Duplicates: Back → Next after a failed run saved a second mount or job. Back is now unavailable after a successful run.
Mounting Another Folder of the Same Remote: The suggested mount location now includes the folder name, so it no longer collides with the first mount.
Startup, Connections, Multiple Windows, and Licensing
Connection Errors in the App Log at Every Start: Harmless “connection refused” lines for
127.0.0.1:5582are replaced by one information line. -
Connecting to an Rclone That Stopped Responding: The connecting dialog never closed, and switching connections hung.
App Lock Exit and Reset at Start-Up: Exit and Reset App on the lock screen did not stop the previous session’s rclone, and a reset led to a second rclone.
Restarting Rclone From a Secondary Window: Other windows stayed on the old rclone and lost their connection.
Settings Reverted Between Windows (Windows): A setting saved in one window could be overwritten by another.
A Secondary Window Lost Contact With the Main Window: After one lost reply, every later request failed until the window was closed.
Notifications Replaced Earlier Ones (Windows): A new notification could silently replace an earlier one.
License Registration on Windows Server: Registration and email notifications failed with a certificate error where Amazon’s root certificate is missing. It is now built in for these connections only, without disabling certificate checks.
License Registration Error Messages: Server-side failures no longer suggest a proxy problem, and Copy details includes the actual reason.
Trial Messages: The trial ended message could appear twice, and PLUS Trial Ended could show right after registering a license.
Language and Interface
White Dialogs in Dark Mode: The Synology NAS Detected window and the RcloneView Mobile title bar showed white text on white.
Long Names in Trees: Long folder and filter rule names are now shortened with “…”, and remove buttons stay visible.
Packaging and Updates
The AppImage Quit at Start on Recent Distributions (Linux): On openSUSE Tumbleweed, Slowroll, and similar, the AppImage quit at start because it bundled an older system graphics library. It now uses the system’s.
The AppImage and a Long PATH (Linux): Could crash or hang when
PATHwas 4096+ characters or had an empty entry. -
Saving Mounts Without xdg-user-dirs (Linux): The database could not be opened; the app’s own data folder is now used.
The Terminal Tab Broke the App’s Signature (macOS): Opening it added a file inside the app bundle; that file now lives in the app’s support folder.
A Silent Install Could Be Rolled Back (Windows): A silent install could exit with code 5 and keep the old version when a Windows service held the app’s files, and the installer closed unrelated programs. It now closes only RcloneView and its bundled rclone, waits for them to end, and leaves other rclone copies running. An interactive install asks first.
Thank you for using RcloneView!
