Rcloneview: command not found
Just downloaded and installed rclone_view-1.4.45+1-linux-x86_64.deb on a MX Linux 23 following the steps on this link, except Step 2 I replaced by
sudo apt install ./rclone_view-1.4.45+1-linux-x86_64.deb
instead.
But on Step 4 upon launching rcloneview I get “rcloneview: command not found”.
$ fusermount3 --version
$ fusermount3 version: 3.14.0
$ echo $PATH
/home/AdOS/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games:/sbin:/usr/sbin
If I run rclone_view I get no errors, nothing pops up and I get next prompt.
Just to make sure to clear any mishap, I then run:
$ sudo dpkg -i rclone_view_*.deb
(Reading database … 492349 files and directories currently installed.)
Preparing to unpack rclone_view-1.4.45+1-linux-x86_64.deb …
Unpacking rcloneview (1.4.45+1) over (1.4.45+1) …
Sorry to see you go.
Setting up rcloneview (1.4.45+1) …
Processing triggers for desktop-file-utils (0.26-1) …
Processing triggers for mailcap (3.70+nmu1) …
Processing triggers for hicolor-icon-theme (0.17-2) …
$ sudo apt-get install -f
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
$sudo apt-get install fuse3
fuse3 is already the newest version (3.14.0-4).
$fusermount3 --version
$rcloneview
$rclone_view
$rclone_view
$rcloneview
$ls -al /usr/share/rclone_view/
total 60
drwxrwxr-x 4 root root 4096 Jul 24 21:47 .
drwxr-xr-x 493 root root 20480 Jul 24 20:52 ..
drwxrwxr-x 4 root root 4096 Jul 24 21:47 data
drwxrwxr-x 2 root root 4096 Jul 24 21:47 lib
-rwxr-xr-x 1 root root 24568 Jun 22 23:57 rclone_view
$sudo rclone_view
$/usr/share/rclone_view/rclone_view
Using rclone alone, rclone-browser they are working just fine, as expected.
Not sure what I’m missing. Any help deeply appreciated.
Below my QSI, just in case:
System:
Kernel: 6.1.0-51-amd64 [6.1.177-1] arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.1.0-51-amd64 root=UUID= ro nvidia-drm.modeset=1
nvidia-drm.fbdev=1 quiet splash init=/lib/systemd/systemd
Desktop: KDE Plasma v: 5.27.5 wm: kwin_x11 vt: 7 dm: SDDM Distro: MX-23.6.1_KDE_x64 Libretto
May 18 2025 base: Debian GNU/Linux 12 (bookworm)
Machine:
Type: Desktop System: ASUS product: N/A v: N/A serial:
Mobo: ASUSTeK model: TUF GAMING X570-PRO (WI-FI) v: Rev X.0x serial:
UEFI: American Megatrends v: 4021 date: 08/10/2021
CPU:
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4 level: v3 note: check
built: 2022 process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x21 (33) stepping: 0
microcode: 0xA20102E
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache: L1: 768 KiB desc: d-12x32
KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3305 high: 4206 min/max: 2200/5619 boost: disabled scaling:
driver: acpi-cpufreq governor: ondemand cores: 1: 4199 2: 4206 3: 4180 4: 2200 5: 2200 6: 4182
7: 4200 8: 2200 9: 4198 10: 2200 11: 2200 12: 2200 13: 4198 14: 2800 15: 4200 16: 4200 17: 4198
18: 4200 19: 4178 20: 2200 21: 2200 22: 2200 23: 2200 24: 4199 bogomips: 201604
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
Device-1: NVIDIA GA107 [GeForce RTX 3050 8GB] vendor: ASUSTeK driver: nvidia v: 580.142
non-free: 530.xx+ status: current (as of 2023-03) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 ports: active: none
off: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 0a:00.0 chip-ID: 10de:2582 class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 5-1.4:6 chip-ID: 046d:085c class-ID: 0102 serial:
Display: x11 server: XOrg v: 1.21.1.7 with: Xwayland v: 22.1.9 compositor: kwin_x11 driver: X:
loaded: nvidia unloaded: fbdev,modesetting,nouveau,vesa alternate: nv gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 162 s-size: 602x341mm (23.70x13.43") s-diag: 692mm (27.24")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: ViewSonic VX2776-4K serial:
built: 2024 res: 3840x2160 hz: 60 dpi: 163 gamma: 1.2 size: 597x336mm (23.5x13.23")
diag: 685mm (27") ratio: 16:9 modes: max: 3840x2160 min: 640x480
API: OpenGL v: 4.6.0 NVIDIA 580.142 renderer: NVIDIA GeForce RTX 3050/PCIe/SSE2
direct-render: Yes
Network:
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel modules: wl pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlan0 state: down mac:
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 8086:15f3 class-ID: 0200
IF: eth0 state: up speed: 1000 Mbps duplex: full mac:
Bluetooth:
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:2 chip-ID: 8087:0029
class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: bt-v: 3.0 lmp-v: 5.2
sub-v: 21c1 hci-v: 5.2 rev: 21c1
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff link-mode: peripheral accept
service-classes: rendering, capturing, object transfer, audio, telephony
Drives:
Local Storage: total: 15.01 TiB used: 7.99 TiB (53.2%)
SMART Message: Unable to run smartctl. Root privileges required.
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB size: 1.82 TiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial:
rev: 5B2QGXA7 temp: 38.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:15 vendor: Western Digital model: WD BLACK SN850X 4000GB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD
serial: rev: 624311WD temp: 39.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS500G2B0A-00SM50 size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: rev: 20WD
scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD40EZRZ-00GXCB0 size: 3.64 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial:
rev: 0A80 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WDS200T2B0A-00SM50 size: 1.82 TiB
scheme: MBR
ID-6: /dev/sdd maj-min: 8:48 type: USB vendor: Micron model: CT4000X10SSD9 size: 3.64 TiB
block-size: physical: 512 B logical: 512 B type: SSD serial: rev: 1000 scheme: GPT
SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
Partition:
ID-1: / raw-size: 40 GiB size: 39.08 GiB (97.69%) used: 35.77 GiB (91.5%) fs: ext4
dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%) used: 37.9 MiB (3.8%) fs: vfat
dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 361.33 GiB size: 354.59 GiB (98.14%) used: 61.64 GiB (17.4%) fs: ext4
dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /opt raw-size: 58.59 GiB size: 57.37 GiB (97.92%) used: 3.56 GiB (6.2%) fs: ext4
dev: /dev/nvme0n1p9 maj-min: 259:9
ID-5: /tmp raw-size: 19.53 GiB size: 19.06 GiB (97.57%) used: 11 MiB (0.1%) fs: ext4
dev: /dev/nvme0n1p7 maj-min: 259:7
ID-6: /usr raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 16.93 GiB (17.7%) fs: ext4
dev: /dev/nvme0n1p5 maj-min: 259:5
ID-7: /var raw-size: 58.59 GiB size: 57.37 GiB (97.92%) used: 32.7 GiB (57.0%) fs: ext4
dev: /dev/nvme0n1p6 maj-min: 259:6
Swap:
Kernel: swappiness: 15 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 23.76 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p11 maj-min: 259:11
Sensors:
System Temperatures: cpu: 55.2 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 0%
Client: shell wrapper v: 5.2.15-release inxi: 3.3.26
Boot Mode: UEFI`
SOLVED!
Right after running rclone_view on the CLI, I went to check the Quick System Info’s Journald tab and saw the message:
“rclone_view libsecret_error: Failed to unlock the keyring”
What happens is this error occurs because the rclone_view graphical interface attempts to read or save encrypted credentials for my google account, but the system password manager is locked, so it is unable to get them.
But why the SPM is locked? Because my MX Linux is set to automatic login on every boot or restart of the system for the sake of convenience. And autologin prevents the keyring from unlocking automatically.
So I switched to login on every boot or restart and…
Alas! I’m back to business!
Issue resolved.
