Could you please check if the rclone_view binary was correctly installed?
You can do this by running the following command:
ls -l /usr/share/rclone_view/
If you see a binary named rclone_view in that directory, try executing it directly from the terminal:
/usr/share/rclone_view/rclone_view
This will help us confirm whether the issue is with the installation itself or with the desktop shortcut not launching properly. Could you let us know the result?
so, /usr/share/rclone_view/rclone_view gave me this error:
/usr/share/rclone_view/rclone_view: error while loading shared libraries: libayatana-appindicator3.so.1: cannot open shared object file: No such file or directory
