Remote Rclone - Test is successful, connection fails
Hi all,
Brand new to Rclone View.
Looking to manage my externally hosted Rclone instance running on a Linux VPS.
I have a Macbook Air with M3 running Sequoia (15.4.1) and RClone View (0.6.294)
I use Connection Manager and configure a connection to my external Rclone instance (v1.69.2)
Test Connection - successfully connects
Save the connection
Go to Connect and get error
“Connection failed
Unable to connect to the server. Please check your connection settings and server status and try again.”
Application logs show:
[error] | 0:05:40 850ms | fetchRemoteItems - Failed to parse JSON. Response body: {
“remotes”: null
[error] | 0:05:40 850ms | fetchRemoteItems - Error: Exception: Failed to parse JSON response
Is this a bug or have I done something wrong?
Same for me.
Mac version. I can’t use it anymore.
Please try this version, which handles JSON parsing errors during fetchRemoteItems.
macOS:
https://downloads.bdrive.com/rclone_view/builds/RcloneView-0.6.303.dmg
Windows:
https://downloads.bdrive.com/rclone_view/builds/setup_rclone_view-0.6.304.exe
it says that app.koofr.net/core/version doesn’t exist.
Still the same problem with Version 0.7.318 (318)
