Dear Sirs,
How can I select a specific folder from any hard drive on my PC? When I choose the “Local Disk” option, it automatically selects the root folder of the HDD where the operating system is installed, without offering any alternatives. Also, setting a default location under Locations in Settings doesn’t seem to make any difference.
Thank you.
From your message, it looks like you are using the macOS version of RcloneView. On macOS, other mounted drives and partitions can be accessed under the /Volumes directory of your boot disk. You should be able to navigate there to select the specific folder you want.
