Trying to server-side copy on an S3 remote (move one folder into another), but no matter what global flags I set in rclone, the file processing speed is stuck at 2-3 files per second. And this is a server-side copy as well.
Here are my rcloneview global flags: --no-check-certificate;--ftp-no-check-certificate;--s3-directory-markers;--s3-upload-concurrency "32";--s3-upload-cutoff "32M";--transfers "64";--checkers "64";--s3-chunk-size "16M";--delete-empty-src-dirs
When I execute the same operation using CLI -P --transfers 64 --checkers 64 --s3-chunk-size 16M --s3-upload-cutoff 32M --s3-upload-concurrency 32 --exclude-from rclone_exclude.txt --ignore-case --delete-empty-src-dirs, the move speed was 20.7k files processed per minute, 610MiB total, finished in 1minute 26 seconds.
With RcloneView, moving one folder into another on the same S3 remote the file processing speed is 2-3 per second. It doesn’t seem like setting --transfers or --checkers in global rcloneview flags does anything. I also tried using --delete-empty-src-dirs, it also seems to not do anything. Did multiple complete restarts, including rcloneview, rcd, rclone.exe, etc. Still nothing.
Am I doing something wrong? Or is there really no way of setting copy/move flags? Without this, RcloneView’s transfer speed is literally less than 1% of using CLI in the example above, at which point it completely loses its point.
