Suggestion: move rclone_view.db to ~/.local/share
Hi,
Could you change the default path for rclone_view.db? Right now it sits in ~/Documents, which clutters the user folder. Moving it to ~/.local/share/rclone_view/ would follow XDG standards much better and keep the Home directory clean.
Maybe the app could just check for the old path first for backward compatibility?
Thanks!
Hi @xVANKO,
Great suggestion — you’re absolutely right that ~/Documents isn’t the ideal location for the database file.
We’ll be updating the default path for rclone_view.db in the next version to follow platform-standard conventions:
  • Linux: ~/.local/share/rclone_view/
  • macOS: ~/Library/Application Support/com.bdrive.rcloneview/
  • Windows: C:\Users\<user>\AppData\Roaming\com.bdrive\rclone_view\
For backward compatibility, the app will check for the existing file in the old location first.
Thanks for the feedback!
We’ve updated the default path for rclone_view.db in version 1.4.17.
You can grab the update here:
The app will check for the old path first for backward compatibility.
Let us know if you run into any issues!
Thanks
