Support FUSE-T (macOS)
I cannot create a new topic. I get the error “An error occurred: You are not permitted to view the requested resource.”
I cannot create a new topic so am posting here about my problems with Mount Manager.
Mount Manager does not work with FUSE-T
First off. Thanks for an amazing product with even a version for Mac. I will certainly sign up for the annual subscription when my 14-day trial expires.
I wanted to try out the Mount Manager but I get the error that macFUSE is not installed. I do not use macFUSE as the use of kexts is deprecated. Instead I use FUSE-T & sshfs. Can RCLONEView be fixed to use FUSE-T?
Hi @nigelbb,
We’ll modify it to no longer check for macFUSE installation. I’ll keep you updated.
Thank you for your feedback!
Hi @nigelbb,
Please use the following version, which includes fixes to support FUSE-T:
Download RcloneView-0.2.179.dmg
This change will be included in the next release.
Tested & working. Thanks a lot.
