Description
RcloneView currently supports Sync and Bi-Directional Sync operations.
Weβre now planning to expand to a wider range of Job Types, including:
Copy β One-way file duplication without deletion (coming next sprint) -
Move β Copy then delete source (useful for organizing cloud storage) -
Delete β Remove files from a specific path or remote -
Purge β Hard-delete entire folders (no trash, no versioning)
Each operation serves a distinct use-case and allows users more control over their file management strategy.
Usage Scenarios
CopyA user wants to back up local files to both Dropbox and Google Drive β without affecting the source files.
β Copy ensures one-way backup with zero risk of source loss.
MoveA user wants to transfer processed files to cold storage (e.g., from NAS to B2).
β Move clears up local space after cloud transfer.
DeleteA user cleans up temporary logs or cache directories in a scheduled job.
β Delete removes specific file types from a cloud path.
PurgeA user wants to remove an entire backup folder from a cloud remote after archiving.
β Purge removes all files instantly, including any leftover metadata or empty dirs.
Reference Behavior
rclone copy β preserves source, overwrites target if changed
rclone move β equivalent to copy + delete
rclone delete β deletes file(s) at target path only
rclone purge β aggressively deletes folder + all contents
These are standard Rclone commands, but not yet exposed in RcloneView via UI workflows.
Limitations to Note
| Current Limitation | Clarification |
| Copy is coming in the next sprint | UI and logging logic being finalized |
| Move/Delete/Purge may require confirmation safeguards | Extra UX validation is needed to prevent accidental deletion |
| Not all remotes support purge | Rclone will fallback to recursive delete if unsupported |
Roadmap (Vision)
Add Copy as a selectable Job Type (next sprint) -
Add Move with visual confirmation of delete-on-source -
Introduce Delete and Purge with βDry Runβ preview mode -
Add safety toggles (e.g., βrequire confirmation for destructive jobsβ) -
Allow batch job templates with mixed job types
Want this feature?
Upvote this post if you want more flexible job types beyond Sync β like Copy, Move, or Purge β directly in RcloneView!
Have a specific use-case for these operations? Let us know below ![]()
