Terminal on Mac doesn't know path to RcloneView's built in rclone
Hello experts,
I’m on macOS 26.5.1 with RcloneView 1.4.48.
When I’m opening the Terminal window in RcloneView and entering a rclone command – no matter which command – I get:
zsh: command not found: rclone
Apparently the Mac doesn’t know the path to RcloneView’s built in rclone.
Any ideas how to fix this?
For your hints many thanks in advance!
The rclone is embedded and you’d need to use something like:
/Applications/RcloneView.app/Contents/MacOS/rclone_arm64 (and then put your command here)
Thank you for the hint!
It lead not directly to the solution but I got the solution from Google AI. It can be found here: Google Search
Or you could use the whereis command in terninal
whereis rclone
rclone: /Applications/RcloneView.app/Contents/MacOS/rclone
that doesn’t work - have rcloneview on macos and shows nothing for rclone
Funny it works on my Macbook M1 running macOS 26.5.2….
But I did notised that it only gives me the path (path to the binary) if RcloneView is actually running, if RcloneView is not running it only gives me rclone: in terminal.
Edit.
Actually I was thinking of the which command and not whereis.
From what I can see which works if RcloneView is running or not.
