Terminal should be restartable and not start by default
Hi!
I recently used the builtin terminal (rcloneview on windows) and typed exit.
There is no way to restart the builtin terminal other than restarting the application.
And this also seems to tell that the terminal is started by default.
What I would suggest is to only “really” start the terminal when opening the terminal tab and to build in an option, shortcut or key-combination (shown to the enduser in the closed terminal) to restart the terminal.
Thanks in advance
Peter
