Windows display problem
Hello,
I recently install the lastest version of RcloneView on a Windows 11 system. After a short time and if I do not click on anything on the window, the window becomes empty and I see only the border of it. It is impossible to interact with it after that and I have to kill the process using Windows tasks manager. It is a real problem when it is configure to open at startup on the Windows session.
However, if in the short time (some seconds no more) I can see the content of the window I click on something, it is stable after that : I can close it, reopen by the tray icon, etc.
Any idea ? Thanks
Thank you for reporting this issue.
We’ve prepared a new build that includes fixes for the window becoming empty as well as the “Start at login” problem you mentioned. Please try the following version:
Thanks again for helping us improve RcloneView!
Hello,
It works here on Win11 : RcloneView starts well at login as tray icon.
Thanks a lot.
Hello,
I am still facing similar issue on my Win11 for the latest 0.9.444 version. My Win11 version is 24H2 OS Build 26100.6584 if this helps.
Thanks for looking into this issue!
